Off throttle (or idle) it should definitely be off boost.So I have a boost gauge hooked up to my car and I'm finding the car showing some form of boost almost continuously. Even just cruising at a steady 60 mph. Is this normal for this engine?
Where are you tapping in for the boost gauge pressure reading?Interesting. And yeah, I was seeing no boost or even negative numbers while engine braking (off throttle). I've never had a car with a turbo so was surprised to see that. Thanks.
I'm using something called an Ultragauge, that just takes readings off the OBDII port. I have one for my other car and find it really useful for maximizing my fuel mileage. You can set it up to read just about anything that the car has available and reports on. I was also surprised to see that the coolant temps are running between 174 - 176 F. This car definitely has a good cooling system.Where are you tapping in for the boost gauge pressure reading?
That makes sense. I haven't used that specific product, but I have used others like it.I'm using something called an Ultragauge, that just takes readings off the OBDII port.
I had looked at the UltraGauge, but their compatibility list stopped at 2015 and didn't mention Fiat anywhere... Since you have two now, I'm going to assume that you like it?I'm using something called an Ultragauge, that just takes readings off the OBDII port. I have one for my other car and find it really useful for maximizing my fuel mileage. You can set it up to read just about anything that the car has available and reports on. I was also surprised to see that the coolant temps are running between 174 - 176 F. This car definitely has a good cooling system.
Heres the link; http://www.ultra-gauge.com/ultragauge/
