Questions about the battery and charging system
7794 Views 23 Replies 10 Participants Last post by  lordofthewings
Has anyone else been monitoring the battery voltage of their car while running? I'm noticing that at idle I measure only around 12.6 volts right after starting. And after cruising even 20 miles or so at highway speeds of 60 mph, I almost never see even 13 volts. After driving 40 miles today, all on the highway, it finally was showing around 13.2 volts of charging. Don't these numbers seem really low? I'm expecting to see upper 13's and above 14 some of the time, but have never seen even close to that.
21 - 24 of 24 Posts
What's the ideal AMP for a battery tender for the spider. there are some.750 amp 1.25
3 amp and so on. tia
This is the one I ordered. 1.25 is about optimal for modern cars.
http://www.ebay.com/itm/291811749308?_trksid=p2057872.m2749.l2649&ssPageName=STRK:MEBIDX:IT
OK you guys have the weather. But you've also got ....:eek:
No politics in my threads please. Thanks.
I've got a Ctek 5.0 charger which I have used extensively and would recommend - but, I haven't ever tried the connection to 12v outlet.
http://www.ctek.com/gb/en
Thanks for all the helpful replies.
Reactions: 1
21 - 24 of 24 Posts
