I'm not that tall, about 5'6" and currently using wedge cushions which aren't that comfortable and need adjusting every time I get in the car. Any ideas about raising the whole bucket seat about an 1 1/2" off the floor?
I think the big issue will be contact between the top of the sear structure and the soft top.Thanks so much.
If when using a seat cushions, say 1" compressed when sitting on it, and your head did not touch the soft top then adding a 1 inch spacer to the rear and removing the seat cushion would not be an issue.I think the big issue will be contact between the top of the sear structure and the soft top.
I am 5” 4’ and have decided that the safest way is a simple seat cushion.
Very clean installation. How was the rectangular tube attached to the floor and rail?View attachment 90639
My engineer used 40mm x 40 mm coated steel rectangular tube to raise the seat height.
It has worked well, I am more comfortable without the cushion, have satisfactory sight lines and will have the comfort of a heated seat in winter.
