1 - 4 of 4 Posts
I want to cover my seats.I found the two nuts in front. But I am not sure what to remove in the rear. I see what looks like a Torx bolt. Not sure if that's the rear bolt as it is in an opening in the rails.
Be careful of the airbags!
You might want to explore this situation in depth. I was told that the airbags are in there and should be handled with care. Be careful.
Cyberbill. Austin
If you're getting it covered by a professional upholstery shop, they should be able to remove it. Or will this be a Diy project?
I DYI it on my Tacoma with Coverking leatherette. But I removed the seats. I have no issue removing the Fiat seats but I need to know where all four bolts are. I can disconnect the speaker and Airbag connector.
1 - 4 of 4 Posts
