Just in case anyone is interested in replacing their turn signal bulbs with LEDS and wants a quick and easy way then I can highly recommend going for the lighting harness from MX-5 things as a simple plug and play way to prevent hyper flashing. https://store.mx5things.com/item/rear-light-unit-harness
You need 1 harness for the left rear, and another for the right rear and then you can replace both front and rear turn signals with LEDs. They take about 2 minutes to install and allow you to buy the cheaper LEDs without built in resistors which also may run a little cooler.
If you are looking to also change the side turn signals then you need to replace the actual side turn signal unit since the OEM one has the bulb/unit as a single item with the bulb not being replaceable.
There are a couple of options that I am aware of. IL Motorsports and Blinkerhaus.
IL Motorsports (Smoked or Clear) which are sold by Moss Miata in the US, or direct from IL Motorsports in Europe
https://mossmiata.com/2016-2017-mx-5-miata/exterior/lights-lighting/smoked-side-marker-lights-by-il-motorsports
https://mossmiata.com/2016-2017-mx-5-miata/exterior/lights-lighting/clear-side-marker-lights-by-il-motorsports
I went for the clear ones. Note: you still need to buy a separate LED bulb.
Another option although I have not tried them myself is Blinkerhaus
https://www.ebay.com/itm/MAZDA-6-GH-ATENZA-MAZDASPEED-5-RX-8-MX-5-RF-ND-SMOKED-FENDER-SIDE-MARKERS-LIGHTS/323302623684
TheSalamander
TheSalamander
