101 - 103 of 103 Posts
It's a Mazda roof and Mazda has a service bulletin on it also. The fix didn't really hold on my roof for more than a few days and our tops already incorporate the fix to begin with. I finally just glued the edge into the j-track instead of using the clips alone. That was over a year and a half ago and it's been fine since. (At the time, replacement roofs would have taken ages to get anyway.)
Hello,what glue did you use? Also there are 3 layers, so just above the inner layer is a loose material. Where does that go? It seems to go behind the rail of the bottom layer then the rail pushes into the track. Is that right?
JF, I have the same problem with convertible top sagging and obscuring my view out the rear window when the top is up. Any idea the part number or specific name so that I can order a clip to avoid having to tuck it back up in? I can take it to the dealer but it is an hour away and would rather just get the parts and fix myself. The Mopar site is useless unless you know exactly what you want. Thanks.
I have 2019 Abarth, same issue, the back became detached from the section above the rear window. It was difficult to put back in.
I contacted the dealership, apparently someone with a 2017 had the exact same issue, the only solution was to replace the entire cowl.
Luckily my warranty is still active, otherwise it would have cost $5k!!!
