No real issue noticed in that regard, despite changing the wheel/tire setup every few days. You do need to push the tire pressure 'reset' button at the left lower part of the dash each time you change wheels/tires or it might think you have a tire going down after you drive a bit because of the diameter change, but that's it.Brian, did you need to recalibrate the speedo for 17's since you car is a Classica? If so with what?
