1 - 9 of 9 Posts
2018 124 Spider Lusso Red Top Edition, Automatic, Fashion Gray, Ivory Interior, Bordeaux Top
I discovered a new way to have fun with the automatic today. Whenever I came to a stop and turned onto a new road, I floored the accelerator and short-shifted the automatic at 4,000 rpm. You are right in the meat of the torque curve and the shifts are lightning quick, as in blink-of-an-eye quick. There's no way anyone could shift the manual that fast. The rpm will drop about 850 rpm (my car is stock) and quickly hit 4,000 rpm again.
If you do this at 3/4 throttle, you can accelerate the car almost like a CVT at a constant rpm. I was not letting the rev counter go over 3,900 rpm. It was like Bang! 2nd Bang! 3rd Bang! 4th Bang! 5th. Felt like shifting a DCT.
On my next outing I will try short-shifting at 4,500 rpm.
For street driving at speeds up to say 75 mph, there's really no reason to wind out the motor beyond 4,500 rpm because the torque starts dropping off. What you need is torque, not horsepower, and short-shifting lets you keep the engine on the fat part of the torque curve. If you want to run at higher speeds, then of course horsepower comes into play and the peak at 6,000 rpm is needed to overcome increasing atmospheric drag.
Product Rectangle Plot Slope Font
I played all summer doing this. If you have a pedal installed start playing with the settings for this kind of shifting at these rpm,s You will be amazed at what you will feel. It seems you are stuck to the back of your seat from 15mph all the way to 65mph or more. The constant torque is quite impressive for this little engine. I was shifting around 3900 to 4100 and like you say it is bam bam bam.
Turbo engines and automatics are a good combination.. What is your left foot doing to keep busy?
My left foot is glued to the dead pedal during "spirited driving".
Using the paddles I assume?
Discussion Starter · #8 ·
Would be nice to have paddles, but alas @Chipshot is correct. I have a Lusso that didn't come with paddles. So I bump the stick over to the left and row it back and forth like manual playing between 3rd and 4th.
What are you driving?
Sorry, created a new profile in error. Driving a 2017 Abarth automatic. GFB +, Sila Turbo blanket and catch can added under the hood. I put paddle extenders on my paddles and they work great, going to try the quick shifting out.
1 - 9 of 9 Posts
