I've been having a cold starting issue with my '17 spider for months that has only seemed to get worse. It started as an initial hesitation to 900-1000rpm and then would slowly make its way up to 2200. Now it goes to about 1100 and stalls out on the first start, then starts perfectly on the second ignition - every time. If I start the car again on a warm engine it has no problem, car runs great once it's running. Here's a video of a cold start I did this morning. My car has 30k miles and I only put 93 in it. Ambient temperature does not seem to make a difference.
Here's what I have checked/replaced so far:
Oil level is good
New AGM Group 35 battery (was stock)
New EC gapped NGK SIKR9A7 spark plugs (was stock)
4C coil packs (figured I might as well if I was replacing plugs, was stock)
Cleaned EC V2 intake filter
Nothing has seemed to affect the cold start behavior. Any ideas?
UPDATE: a bottle of Techron has appeared to fix my problem. Car starts perfect again. Who knew I only needed to spend $8.
Oil level is good
