1 - 20 of 25 Posts
I wonder why speedometer and tach were frozen at 130 mph and 7k rpm? they acted like black box>
Speedometer Vehicle Tachometer Plant Trip computer
Car Vehicle Motor vehicle Steering wheel Automotive tire
Wheel Tire Car Land vehicle Vehicle
I would break the speedometer glass and bring that needle down, that way the police won t ticket you for speeding and and insurance won t find an excuse not to pay for the accident.
I may be wrong, but I thought they could poll information from the electronics in the car to retrieve the driving conditions prior to a crash (speed, acceleration, braking, etc.). Manually pushing the needles on the dials around won't hide much from the insurance folks or police, if they choose to pull the data from the vehicle's computer systems. Maybe not true for vehicles more than a couple of decades old, but for our Spiders, I think the data is all safely stored away for retrieval.
2020 Abarth 6MT Modded To The Moon
The unit that records that info is the “black box”. Now sure if we have one…?
Discussion Starter · #9 ·
Holly sh!t you ok? I thought my crash was bad. Then again I wasn’t going 130mph!
This isn’t your car right? Your signature shows a red spider.
Not mine
Here is another example -frozen at 45 mph and 8k rpm
Automotive tire Motor vehicle Automotive lighting Automotive design Steering part
Yes, Calvin, you would be correct ( Again! 😃). When the airbag(s) are deployed, the SRSCM (Supplemental Restraint System Control Module) stores vehicle data at the time of the crash/deployment and for a short period of time before said crash by law. Best, s
Book Publication Font Paper Paper product
This is from pg's 146-147 of my 2018 owners manual. The full text continues onto pg. 148, basically explains what is recorded, why, what happens at/after an event. In short, the system records data such as vehicle speed, accelerator, brake and steering inputs, occupancy detection and if seat belts were buckled - for a short period of time before, during and after a crash. It also, upon a crash event, cuts off vehicle power and fuel delivery and unlocks the doors. It will set a DTC indicating a crash has occured, which you cannot erase, and special equipment (available to police dept's as well as the manufacturer and dealers) is required to access this data. Best, s
About recorded/saved data - a quick little story about one of my customers and his car ( not a Fiat, and not crash related ). A good customer I had known for years brought his car in due to the check engine light being on. He also needed a state inspection sticker which requires that the cause of the CEL be fixed. Well, turns out it was a transmission selected gear / road speed correlation issue, as well as front wheel speed and rear wheel speed correlation DTC set in the ABS system. I also had to fail the car for a sticker because the front tires were worn absolutely bald, with straight line grooves cut into the circumference of the tire ( it was a front wheel drive car). I told the customer I could clear his codes, he didn't need any mechanical or electronic repairs at this time ( transmission fluid level/odor/color all ok, and transmission performed and shifted properly at this time), but that he would need two new front tires for a sticker. "WHAT!? The cars only got 10,000 miles on it!!! Why the F--- do I need new tires?". Good question, I understand why he's pissed, I would be too, but . . . So, I showed him the data that the car recorded when the codes set: front wheels smoking at 112 mph, rears were only going about 25. Then I showed him his tires - fronts terribly worn as described above, rears almost perfect. "Oh, . . . " He said. "Guess I gotta go home and have a very one sided chat with my boy . . ." 😃 Hope you all enjoyed this little true story. Best, s
About recorded/saved data - a quick little story about one of my customers and his car ( not a Fiat ). A good customer I had known for years brought his car in due to the check engine light being on. He also needed a state inspection sticker which requires that the cause of the CEL be fixed. Well, turns out it was a transmission selected gear / road speed correlation issue, as well as front wheel speed and rear wheel speed correlation DTC set in the ABS system. I also had to fail the car for a sticker because the front tires were worn absolutely bald, with straight line grooves cut into the circumference of the tire ( it was a front wheel drive car). I told the customer I could clear his codes, he didn't need any mechanical or electronic repairs at this time ( transmission fluid level/odor/color all ok, and transmission performed and shifted properly at this time), but that he would need two new front tires for a sticker. "WHAT!? The cars only got 10,000 miles on it!!! Why the F--- do I need new tires?". Good question, I understand why he's pissed, I would be too, but . . . So, I showed him the data that the car recorded when the codes set: front wheels smoking at 112 mph, rears were only going about 25. Then I showed him his tires - fronts terribly worn as described above, rears almost perfect. "Oh, . . . " He said. "Guess I gotta go home and have a very one sided chat with my boy . . ." 😃 Hope you all enjoyed this little true story. Best, s
Nah, just rotate 'em.
2017 124 Classica
It's also possible that the frontal impact lifted the rear wheels off the ground to free spin for a moment before the engine fuel shut off on the engine kicked in.
Reactions: Brody
2017 124 Classica
The suggestion I made was based purely on the idea that if the car had actually impacted at 130mph the damage would likely be quite a lot worse.
.... Assuming it hit a stationary object. It could look like that if it rear-ended something that was travelling at highway speed, possibly?
Calving if the driver got killed or homicide, yes they will go to the black box. Otherwise the cost won't justify the needs. If homicide, believe me they will put the spider on fire thus killing the beast. LOL
1 - 20 of 25 Posts
