1 - 20 of 21 Posts
· Vendor
I am in Japan at the moment and when I visited the local dealer, I was surprised to find they have both the Abarth 595 Turismo, and the 595 Competizione in stock.
That got me thinking. I'll bet most 124 owners don't know about the various levels of power the factory offers in these engines. As we are starting to mod the few 124s that are out there, I think some owners may find the information interesting, so here goes:
· Vendor
Discussion Starter · #2 ·
Ok, outside of the US, most 500 Abarths run the 1.4 turbo. It's a slightly different 1.4 then the one we get. They get the T-Jet engine, not the Multi-Air. It's bascially the same with the following exceptions. The T-Jet engine does not have the Multi-Air system. Multi-Air is an upgrade and in the past you had to buy an Alfa Romeo to get the Multi-Air 1.4 Turbo, however we have it in our US spec 500 Abarths, and in the 124s. The T-Jet engine uses a Bosch ECU, and some versions have the smaller IHI turbocharger. We get the much better Garrett turbo.
All that said, with the same parameters, the T-Jet and Multi-Air engines develop essentially the same power from their 1368cc of displacement, so it's worth looking at the Euro engines.
They basically have 4 versions.
1. The base version, T-Jet or Multi-Air has 140 horsepower and as far as I know always has the smaller IHI Turbo. However that may not be true with the Euro 140hp 124, we don't know at the moment.
2. The next step us is the 160hp version. This has the Garrett turbo and is found in all US spec 500 Abarths, our 124s, and the T-Jet Abarth 595 Turismo.
3. The Abarth 595 Competizione has 180 horsepower. We don't get this version in the US, but it's essentially identical to the 160hp version but with a hotter tune. FUN FACT, as measured by the various magazines, the 595 Competizione is no faster to 60mph than the 595 Turismo with 20 horsepower less. This is entirely due to traction limitaions, something that a lot of people just can't understand. The Competizione will leave the Turismo behind once traction isn't an issue, but at low speeds neither car can put all it's power to the ground anyway.
4. The big baddie is the 695 Biposto (two seater). It has 190 horsepower from essentially the same tune as the 595 Competizione but with the addition of an improved intake, and better intercooling with revised piping. The 695 IS quicker to 60 and in any other speed range because it's lighter and more importantly it has a plate type limited slip differential with a dog ring gear box.
I want to add, that I don't think that the 695's intake or intercooler are all that great, they are just a little better than the standard pieces. The intake isn't even a cold air air type.
All this relates to the 124 because we now offer a 200hp "Dynamic" tune with our Euro+Drive Lite system. 200hp is very conservative and isn't much different from the hottest factory tune. Add in a good intake and exhaust and you can easily have even more power all while staying near the tuning levels offered from the factory. That should give some peace of mind to those of you who want more power, but don't want the hassles or decreased reliability often associated with modding cars.
Any idea which version was used in the Renegade? From this, I believe it's roughly the same as the one in my 2016 Classica: turbocharged 1.4-liter four-cylinder that produces 160 horsepower and 184 pound-feet of torque.
According to my local independent tuner / service guy (http://alfacare.co.uk/ ) the turbo and engine configuration on my UK Fiat 124 (140bhp approx ) is identical to the UK Abarth 124 (170bhp approx) - so same turbo. The power difference is mostly down to the way the ECU is configured (exhaust on the Abarth is worth a little bit).
Its completely down to the map. It's why it's not difficult to get to around 200 ( for the consumer, I'm sure it took tuners some time to work it out !l)
· Banned
Interesting.
Nice! Makes me feel better about running the Chipbox. Had some concerns after reading about ring failures on #2 piston in some engines even if a few of those were seriously modded.
The 200hp "Dynamic" tune with our Euro+Drive Lite system. I have the RACE + tune, let me tell you I hear those tunes singing especially with the Sport Mode. It was a Bit ch to instal it, but worth every single minute.
Also, most dyno charts for EU 124s show 150 or more. Same with the supposed 170yp Alfa Giulietta which when dynod was nearer 180 if I recall.
When I bought my Fiat 124 there was a significant eye watering difference in price between the 2 in the UK. When I looked into what the difference were between the Fiat 124 and Abarth 124. It seemed the biggest differences, apart from cosmetic, was just the exhaust and ECU map. It makes me wonder if I can easily give my Fiat 124 the Abarths performance?
Sort of maybe is the answer.
Abarth has limited slip diff, different damper and spring rates (probably more track and less road oriented), different (slightly less restrictive) exhaust and a Sport button (which moves peak torque down the Rev range but doesn’t change peak torque or power). And a more aggressive body kit. So if you do track days and drive at 10/10ths on the road then you probably need the Abarth.
I have the Fiat because I prefer the looks and the more compliant ride but I didn’t like the very artificially strangled power delivery. I’ve had mine remapped (cost about £250). They claim about 200bhp but it’s not been on a dyno. It’s much livelier and now pulls hard up through 6K rpm.
Hi Ian. Interested to see your post on remap. Can I ask which map did you go with ?..... I looking to remap and am UK Lusso owner.
You can quite easily exceed abarth performance with a good tune. I've posted quite a bit of data on real world differences, but the crux of it is I'm running about 1 second quicker in gear (30-70) and 0.4 a second quicker 0-60 than a stock Abarth.
Of course that's just step 1 as it were, plenty more performance on offer if you are inclined !
Hi Arthur.
Hi Arthur. These guys are local to me and did the remap:
A lot of people on here have done a lot to get big power gains and/or to get, mostly, track oriented handling improvements. This isn’t my aim.
I have the Lusso+. I love the clean look of the Fiat and want to keep the car as standard as possible but the standard power delivery was so obviously restricted at higher revs that it bugged me.
I ran a plug in box for a while but all that did was elevate the standard torque - it couldn’t change the shape of the standard torque curve - so it pulled a bit harder but still went flat at about 5000rpm.
With the remap it feels stronger from about 3000-3500rpm and just wants to keep revving right through 6000rpm.
I don’t drive hard all the time so this suits me fine - and I still get about the same average fuel consumption.
Thanks for the info..... I'm looking for exactly what you've described for your 124. I'm in Hampshire a few times a year so may co-ordinate my next trip there with a visit to the tuners..... I'll probably get back to you for a bit more info nearer the time..... let me know if they email you a "refer a friend" discount code !!!
No worries. I went fire There might be other tuners more local to you.
I went for AHM because they were local (I also use them for routine servicing), had a good reputation and I liked them when I visited and spoke to the main guy. After that I stopped looking so there might be someone more local to you.
By all means keep me posted. If you speak to them I’m the guy with the white Fiat 124 (mine was the first Fiat they’d done, all others had been Abarth).
It’s a European thing. BMW is similar except they list wheel hp.
yeh, apparently you've not been around long enough to know about Italians and their hp claims back in the the day. They were FAMOUS for overstating the hp. Usually by quite a bit. All the cars and motorcycles out of Italy did it (60's - 80's ish). Frequently (Ducati, Moto Guzzi, etc) motorcycles claiming 50hp would be found to actually have in the 30's, just like everyone else from that time.
· Super Moderator
Thanks Greg.
Would you regard the MultiAir as an upgrade? Considering all the issues that have been posted here, and an unknown number that were likely mishandled by incompetent dealers, it seems the T-jet would have been a better choice.
best regards
1 - 20 of 21 Posts
