1 - 6 of 6 Posts
This guy gets what its all about. Here is a nice right hand drive version Abarth with record monza. Even though its an Automatic he gets the tires to spin nicely by doing a brake start (i wouldnt do that by the way, you trash your torque converter doing it its not worth it)
I think he has the traction control off, Cause the other day, I wanted to try an agressive start, I was revving around 4k rpm when I released the clutch, the tires spinned while back tires were bouncing.. I should have gave less RPM and slowly.
How does it trash the torque converter??
But wheel hop seems to be a common things in cars that have independent rear suspension, you really have to slip into the burnout or just have some real wet roads and tires.
Massive amounts of heat
I can't see that unless you're pre-loading the car and holding it for a long time, then yes the trans temps will raise up high enough and you'll maybe blow a line or something, but that's about it.
I would be more worried about damaging the transmission and diff if he were to have brought the car up to redline and just neutral dropped it or popped the clutch lol.
1 - 6 of 6 Posts
