1 - 20 of 22 Posts
2017 Abarth 124 Spider
Not to overthink this, but when you open the trunk of the car, the two small lights on the inside top of the trunk lid are supposed to light up, yes? Mine do not...
Reach down and to your left in the trunk. There is a switch there for a trunk light.
I too was wondering what those 2 lights attached to the trunk lid do as they do not light for me either.
It took me a few days to figure this out. I found it in the owner's manual :)
*Face Palm* re license plate lights. Going outside to find the switch... Got it! You guys are awesome....thanks!
Of course I thought the same thing since my NB's license plate light comes on when I open the trunk, so I went hunting to see where the light was and found the one on the panel with a switch, I just left it off until I can verify that when the lid closes the light will turn off.
Yes, they turn off when you close the lid. It says that in the manual somewhere.
Okay great, thank you, I haven't been able to get through the manual, I just picked up the car on Wednesday, I have been busy trying to figure out what changes to make.
:laugh:
Reactions: Mike34 and Jeni
Reactions: SJWhiteley and 5961
Guys how do you dismantle the trunk light housing, I want to attach a LED strip light opposite to this, so I need to remove the light housing. I don't want to break or anything it already looks fragile there. thanks
Gently pry it out. I can't remember if the tabs are on the top or sides, but it came out fairly easily.
I did this exact same thing and yes it is a bit fragile. I found it easiest to simply pop the little black plastic retainers and pull the entire panel out. This way it is easy to access the back of the light housing, attach your wiring and run it behind the paneling to the underside of the forward edge of the trunk. Put in 24 " Led strip lighting. Can't see the actual strip when you are standing behind the car but the trunk is very well lit!. :)
Reactions: SJWhiteley and jleo
1 - 20 of 22 Posts
