So, THAT particular nut you've circled I had fall off on my 500 Abarth. Completely missing. I managed to replace it in situ, but left the stud. The studs had been replaced less than 5000 miles earlier while the engine was out. I wasn't about to pull the entire turbo (which is pretty difficult on the 500 Abarth) for one gd nut.I’m not sure there is room to get a bolt into the one I’ve circled. Some “red” Loctite for installing new studs into the turbo flange, and anti seize on the nuts (so they don’t get stuck on the studs) might be the best solution.
The Blackwing is not out yet, nor is the new M2. So no, not yetTrade for a CT4-V?
j/k
What product do you recommend then? I tried getting one for high temp, apparently not good enough!I don't think loctite will do anything but lube the threads given the temperatures in this area.
Tried to order. He has a very weird checkout page. Says it will contact me with a PayPal request to calculate the shipping manually.
Use copper anti sieze on the threads. The anti sieze will smoke for a few minutes then crystallize. No more issues.This time it had threadlocker and is the third time it has fallen out. There are 4 studs/nuts in total that are on the bottom of the turbo.
Each nut is friggin $14! You can’t even buy the stud standalone. @Calehedron @sharkcohen , have you noticed anything special or different about these studs?
Please help me out with your vast hands-on knowledge.
Which one do you use/recommend personally? @GSpyderUse copper anti sieze on the threads. The anti sieze will smoke for a few minutes then crystallize. No more issues.
Not fun at all @GregLol. Not fun......I'm going to try bolt route. Yes Greg entire stud comes out
Do they have stuffed turbos and performance manifolds? @GregI checked the studs on all three of the 1.4s that are here, none are loose or have fallen out. I was not able to talk to Bryan, but I did talk about it with some of my people here, and everyone has the same question.
How are you guys tightening the studs?
That doesn’t have anything to do with it.Do they have stuffed turbos and performance manifolds? @Greg
The studs were installed by the turbo supplier the first time, and replaced the second time by Bryan.How are you guys tightening the studs?
Two of them do, the other, which is my 500L has the stock turbo with over 120,000 miles on it. The two cars with the upgraded turbos are my 124 and Brandon's 500 Abarth. I put the turbos on both.Do they have stuffed turbos and performance manifolds? @Greg
