1 - 4 of 4 Posts
When you want no noise, no nonsense, just performance.
FIAT 124 Diverter Valve by Go Fast Bits / GFB - DV+
European manufacturers like FIAT are pushing their engines to the limit. Get a DV to match!
GFB’s DV+ diverter valve for the FIAT 124 offers a direct-fit performance solution for the weaker factory diverter valves used.
For the full details on this Go Fast Bits DV+ Diverter Valve for your FIAT 124 please visit the link below:
FIAT 124 Diverter Valve by Go Fast Bits / GFB - DV+ - 500 MADNESS - Auto Parts and Accessories
Discussion Starter #2
The DV+ addresses the factory valve problems with a very simple and elegant solution.
Keeping the factory solenoid retains all the benefits of the stock system, and replacing the valve parts with indestructible metal components ensures strength and reliability no matter how much boost you run.
To view the full product description on the Go Fast Bits DV+ for your FIAT 124 please visit the link below:
Many late-model European cars like the FIAT use ECU controlled solenoid-type diverter valves. This is a good concept because the valve can react very quickly and it only opens when it needs to.
For the full details on the DV+ Diverter Valve by Go Fast Bits for your FIAT 124 please visit the link below:
Discussion Starter #4
GFB’s DV+ diverter valve for the 1.4L Turbo FIAT 124 offers a direct-fit performance solution for the weaker factory diverter valves used.
The DV+ addresses the factory valve problems with a very simple and elegant solution. Keeping the factory solenoid retains all the benefits of the stock system, and replacing the valve parts with stronger metal components ensures strength and reliability no matter how much boost you run.
To view the full product details on the GO FAST BITS DV+ for your Turbocharged FIAT 124 Spider please visit the link below:
1 - 4 of 4 Posts
