Got the car recently and normally one of the first things i do in any vehicle is upgrade the speaker system. With this car I didn’t plan on doing that because, well, the obvious problem of road noise and other sound qualities that come with having a 2 door convertible. I skipped looking at amps and all the fancy stuff i would normally do and just wanted to get a little more clarity. The stock speakers weren’t the worst i had heard but a little bit nicer would be enough for me. Got some Infinifty 3ohm 3/4 in speakers that should’ve fit in the stock housing cause I didn’t want to have to cut away any of the pillars and wanted an oem look. Snipped the factory adapters off to connect the new speakers and secured the crossover to the back of the pillar right next to the speaker. Before putting it back together i tested it one the right side to make sure that there was a difference, and there certainly was. Put it back together and took a video, in case any one was curious, playing two song back and forth between the factory speaker on the left and the aftermarket cheap aftermarket infinity on the right. see below for pictures of putting the speaker in the pillar and the video with audio. I also got a sticker on Amazon to replace the Fiat Logo with an Abarth one. It is the flexible non metal type.
