We stock higher flow injectors, they are on our site in the 500 Abarth section. These are typically used by the E85 crowd because on gasoline the stock injectors with a proper tune and other mods can get you up to about 270whp. I could help more if I knew what you are trying to do.Hi all,
does anyone know of a much higher CC drop in set of injectors (yes will need a tune) and fuel pump.
And what the factory injector & fuel pump rates are?
Cheers,
Ant.
No worries, thanks Greg. PM sentWe stock higher flow injectors, they are on our site in the 500 Abarth section. These are typically used by the E85 crowd because on gasoline the stock injectors with a proper tune and other mods can get you up to about 270whp. I could help more if I knew what you are trying to do.
Anyway: https://shopeurocompulsion.net/collections/abarth-engine/products/atp-e85-injectors
