Haven't seen that yet, but it's almost a certainly that we will see those before people need their first clutch changes.Hi Folks, anyone know of any kits in market yet?
Cheers
Wow, a 15 pound reduction in weight that's bolted to the crank has to make a difference! Of course I doubt you could knock off that much on this car (unless you are comparing a fluid filled flywheel/torque converter automatic to a lightweight flywheel on a manual) but there may still be a noticeable improvement.I agree Greg, plus I don't mind a bit of strip racing which benefits from a bit more clutch bite off the line. And as you pointed out there are usually huge weight savings available with single mass performance flywheels over stock. I saved over 15lbs on my last project car.
It sure did make a noticeable difference but the downside was serious chatter at idle. But worth it my opinionWow, a 15 pound reduction in weight that's bolted to the crank has to make a difference! Of course I doubt you could knock off that much on this car (unless you are comparing a fluid filled flywheel/torque converter automatic to a lightweight flywheel on a manual) but there may still be a noticeable improvement.
