Flyin' Miata, a reputable Miata tuner, is working on a V8 swap package for the ND. Their swap will most likely fit the 124 as well. >
A dedicated page on their site is now up:
https://www.flyinmiata.com/V8/ND.php
Flyin' Miata Facebook page said:You knew this was coming. There's still a long way to go before this is a real thing - but the initial test fit is promising. Very promising.
Most of the work will be done in the virtual realm, but we just had to try this the old fashioned way. Yes, that's a V8 engine stuffed in a 2016 ND Miata.
Don't worry, we are developing parts for the four cylinder as well. Just like we do for all generations of Miata.
Like all of our swaps, this will be a fully integrated car and not just a big engine rammed into a little car.
Definitely a GM V8. Probably the LS3, but we're also investigating the LT1.
The LS3 family of engines gives us the choice of 430 hp, 480 hp or 525 hp - all with a two-year factory warranty.
One of our NB conversions was clocked at 3.8 seconds 0-60 by Road & Track. This car should be at least as fast.
Our goal is to make it seem as if this is a factory-built car, and that means upgrading the suspension, brakes, fuel system, cooling system and everything else to suit the new power level.
Our plan is to use the Tremec T56 Magnum, which is a strong, slick-shifting 6-speed we use in our other conversions. We'll also have an upgraded rear end with an LSD, a new driveshaft and new halfshafts.
A turn-key should be no more than our $50,000 turn-key options for the earlier Miatas. Possibly less.
We will make parts available for DIY builders.
