Yup. Most likely you have air in the system . . . I do believe your analysis is correct by the symptoms you describe. Unfortunately, most techs are paid on a "flat rate" (piece work) basis that allows no time for proper bleeding. In my opinion, the dealer should have a flat bed truck deliver a loaner to your home and take your Spider to the shop - on their time, at their expense. Just my opinion. Good Luck! s. PS: I had the same issue after having my water pump leak repaired under warranty by a Fiat/Alfa dealer. I handled the issue exactly as @mtnghost described. But I notice you also state you still have a coolant leak? Coolant leaking out ? Or just coolant level dropping in the jug as it fills the void as air is displaced? In any event, it shouldn't be your problem to fix - as it shouldn't have been mine to fix. I still think the dealer should drop a loaner off at your home, and pick your car up, and make sure it's fixed properly this time.
