1 - 12 of 12 Posts
Hey everyone! So my coolant levels are running low, and I want to top it off.
But here in Canada, I can't seem to find neither the Mopar coolants (not for less than $100), nor the Mazda FL22.
What other coolants can I use to top off my coolant reservoir? The current coolant has a black color, so I believe the original purple has already been mixed with a green on, so now the color doesn't matter for me anymore.
When I look for FL22 coolant at Amazon, these are the results that show up:
Can I use any of those ones?
Thanks!
You can't find FL22 at a Mazda dealership?
Can you order on Amazon?
I provided a link for when I bought for topping off.
aloha mike
I don't recall which one I used, but my Source was AMAZON as well.
I found this quite helpful:
Although I don't understand why we need to use some special coolant if both Mazda green and Chrysler purple coolants are ethylene glycol.
The Mazda OEM coolant seems to have disappeared from Amazon.
This is the same stuff the car came with, and as Mike34 said, it came from Amazon.
Yep. The Ravenol FL22 is what I purchased, except mine was not the premix. Either way, it matches what the 124 came with and won't turn the coolant black like the purple stuff.
In Canada, go to your local FCA dealership, and order MOPAR sku 68334695aa.
If you want to order it online, here's a URL to purchase it from MOPAR directly. http://parts-catalog.moparrepairconnection.ca/catalog-2/search/68334695AA
This is the FL22 fluid, and it shows as $50.75 CAD, or the equivalent or around $35 USD. You could also go to a Mazda dealership and order the FL22 fluid as well.
I got the Ravenol stuff too, from Amazing Amazon. The level was ‘low’ in the reservoir; there doesn’t seem to be a lot of volume difference between low and high. Not had to top it off after bringing it to the high mark.
1 - 12 of 12 Posts
