1 - 18 of 18 Posts
Prima Edizione #44.
When I shut off the engine (push button in off mode), I notice a high pitch electronic tone that persists for a minute or so, and then shuts off. Any clue what this sound is? Anybody else notice it? It's probably on the upper end of frequency that most of us can hear, so the sound might be there even if you can't hear it.
Prima Edizione #44.
I get this too and also get this on my Jeep trail hawk and Can Am Spyder F3. I think as an earlier poster said that it is the computer (electronics) going through the shut down process.
Maybe two different sounds? I also get it on non-turbo cars.
I remember when cars started using electric fans. They surprised a lot of people.
Reactions: safari
Having come over from a 500 Abarth, I would agree with Greg that you are probably describing a pump that will run to cool the turbo down after shut off. If kept out of boost and run gently when approaching your destination, the pump will sometimes not activate, at least on my 500.
· Vendor
That's absolutely correct, if you drive gently for a few minuets before shutting off the engine, sometimes the pump won't run. For those people coming over from the 500 Abarth, this pump runs less in the 124, I assume because of lower engine compartment temperatures.
This pump doesn't sound like an engine cooling fan, it's much quieter, sort of quiet humming sound.
I seem to recall being around a few cars that had a electric radiator fan that would on a hot Vegas day run even with the key pulled from ignition and your walking way.My understand till a set temp is read the fan runs,anybody familiar with this?
Prima Edizione #44.
I am SO glad you posted this question, and thank you, Greg for answering it! I hear the same sound in my car. My husband cannot hear it.
· Vendor
You're welcome. Not everyone can hear it, it's fairly quiet and kind of a high pitch. This pump is a classic case of Fiat doing something good and then not telling anyone about it. Having a computer controlled after run coolant pump is a great idea. But then they don't mention it in sales information so when people hear it, they thing something may be wrong.
I'm getting
Prima Edizione #44.
I'm getting the same sound but it seems to be coming from the fuse panel.
I'm getting
It's not coming from your fuse panel. It is, as described earlier in this thread, a circulation pump that runs in some (not all instances) when you shut down the engine to help cool down the turbo to prevent damage. It's normal, and my existing Abarth Spider does it (all our cars do), and my prior 500 Abarth did exactly the same thing as well. Northing to worry about.
Greg is right that this is a great feature to have. I owned a Dodge Colt Turbo in 1886 that didn’t have this feature, and the manual stated that you had to let the car idle for a couple minutes before shutting down after running hard so that the turbo could cool down. That was a pain.
1 - 18 of 18 Posts
