1 - 15 of 15 Posts
2017 Classica
I've been stressing night and day on wether I should do a complete retrofit conversion of my ugly halogen lightbulbs. Being ugly isn't the main concern of these bulbs as much as how dim they come from factory. So I figured I might as well jump ship and knock out two birds with one stone with a bright and visually appealing upgrade. But hold on there's a ginormous problem to think about.
HIGH BEAMS CAN'T RUN ON LED/HID
This is caused due to the way the car uses the same bulbs as the high beams for the daytime running lights. The method fiat went with was flickering the voltage to get the halogen running dimmer for daytime use. LEDs and HIDs do not support this. So now I've got a bit of a dilemma on my hands or rather a trilemma if you will.
either I:
1. Screw it I want LEDs I don't care about visual continuity (lowbeam LEDs & highbeam Halogens)
2. Who needs DRLs anyway? imma just turn them off (lowbeam & highbeam LEDs)
3. purchase blue dipped halogen bulbs that are brighter and more white than OEM ( Halogen & Halogen)
It was a close call but I went with option number 3. I don't like deviating away from how the car came from the factory. I also appreciated the fact that I could buy both H11(lowbeam) and 9005(highbeam) in the same brand to get that "yeah it's stock officer" look. the bulbs I went with are the Crystal Vision Ultras from Phillips. There were many reviews that said the bulb still looked a tad yellow and was nowhere near the look of standard 6500k LEDs. While I agree with the ladder statement the former didn't hold up in my experience. After installing I could see a night and day difference. The light is white and somehow twice as bright as OEM. I can't do a comparison because I forgot to take a before picture but take my word for it you'll be able to see so much more.
Left is OEM and right are the crystal visions
Automotive lighting Hood Automotive design Flash photography Headlamp
Incase you haven't noticed I also changed the parking light from amber to white and in my opinion gives the car a more clean front end. the bulb size is a 194 or W5W
New headlights with the DRLs and parking lights
Car Land vehicle Vehicle Automotive lighting Grille
either I:
Hi, I did a full front light Led conversation from Ledperf. I’ve got side light, main beam, high beam and DLR. All works perfect, no flickering or errors. For the high beam/dlr it’s dimmer when on dlr and brighter on full beam. Mine is uk spec the bulb had 3 pins and I just simply switched the old for new bulb so you can get LEDs now which will work just like the dual purpose halogen bulbs-just brighter, much brighter actually 👍
I looked at this as well, but there is a problem with legality in the UK (Aftermarket LED Bulbs: MOT Rules And Legalities), things may change in the future but for now I just didn’t want the hassle come MOT time. Additionally, I wasn’t sure about the match between the OEM reflector bowls/ lenses and the LED bulb and I didn’t want to have to change any of the set up in that regard, I have read that LEDs output light differently, it just didn’t seem as straightforward as I had hoped. I am very rarely out in the car at night and so on balance I went with the brighter halogen option…I was tempted though as LEDs draw far less current and are an improvement in terms of output.
High beams can run on LEDs - you just have to turn off your daytime running lights. Depending on what country you are in, this may or may not be possible.
Hi, my car went through MOT last month-passed fine. I think you need to be careful and buy good quality and ideally emarked. You won't regret upgrading to good quality LEDs they make winter driving so much easier and safer and your car look cool.
Abarth 124 Spider in Isola d'Elba Blue with Heritage Pack
Great job. Take a look at this for your high-beam halogens, you should be able to get these bulbs in the USA:
LED options seem very popular but inserting a LED in a reflector type headlight may have a negative effect on both you and oncoming traffic. In a former life, part of my job was to evaluate wayside signals for trains. It was very interesting to see how such a small change in the filament postion in relation to the refector and lens had a noticeable effect on the train crews ability to clearly see the signal. What was worse, at times a poorly focused red signal could give an appearance of a more orange color possibly giving the crew the opinion it was yellow.
Just a bit of my old RR experience coming back. But, one pet peeve I do have is the prevalent use of fog lights. Not only does to hamper the vision of oncoming traffic it also has a small negative effect on the driver being able to see in the distance. By putting light in an area that doesn't help you see further in front of you, your pupils actually will close slightly reducing you night time vision. There, that's the pilot in my coming out. While I'm on my soapbox did you know once subjected to bright lights it can take up to 30 minutes to regain all of your night vision? I'm the goof ball who lowers the sunvisor at night to block the bright green LED traffic lights. Another gripe is the change from engineering grade retrorefectivity on road signs to high intensity. These reflect so much light back it's sometimes hard to read the sign not to mention what it does to your vision while driving at night.
Rant off.....
2018 Fiat 124 Spider Abarth
Rant off.....
Pretty sure no 124's came with reflector headlights.
Pretty much all applies to projector headlights as well. The relationship between the light source and lens is very important.
I won't disagree that it's important, but it's very different with projectors versus reflectors. Reflectors are designed around a specific light pattern, usually 180 degrees or more of light emitting from an incandescent filament. LEDs tend to be more narrow in their light throw, resulting in odd patterns and light being thrown in unexpected directions and intensities in a reflector housing. A projector housing notably has shields and a more precise lens, which prevent it from throwing light in undesirable directions.
Someone posted photos of halogen vs. LED in the halogen projectors here: Lighting upgrade: headlights, running lights and fogs
The LEDs are throwing essentially the same pattern as the halogen bulbs, you can see in the side-by-side where one of each is installed.
That's pretty impressive.
Definitely. I was prepared to purchase LEDs for my Abarth as it did not list them on the Monroney, but appears a prior owner beat me to it because after I got it, it has LED bulbs in the housing. Wish it had the LED halo rings, but at least I don't have to go digging in there to replace anything now.
2017 Classica
Discussion Starter · #14 ·
doing that was an absolute hassle consider yourself lucky. You have to take off the liner under the fender. I did it the hard way by turning the wheels instead of taking them off.
2017 Classica
Discussion Starter · #15 ·
Rant off.....
It's a pet peeve of mine too. So many cars in my town go straight to LED in their reflector housing. some do it pretty well but others just throw the light everywhere
1 - 15 of 15 Posts
