1 - 20 of 24 Posts
Hello everyone, My 124 abarth won't revs up to 4000rpm, since the first day I've bought it.
Can you explain me why ? and maybe tell me how to get rid of this block ?
thank you
because it is automatic lol
Can provide more information about your car? Year and equipment (MT6 or AT?) Do you have a check engine light displayed? Any messages in the infotainment system? AT or not it should be able to reach red line and most certainly rev above 4000. Not that you want to do it often but will it rev over 4000 RPM in neutral? If it is under warranty then you should take it back to the dealer for an assessment. With more information I'm certain that this community can help you diagnose the issue.
for s
for sure, it is an automatic and nothing is lighted on the dashboard. and no I mean when I’m in neutral or parking I can’t rev up to 4000rpm there is like a block. Later I will tell you the year and maybe I will warm it up and try to send a video
Can't begin to try and assist without more information. Otherwise your post is like calling the dentist and saying "Why does my tooth hurt?" They can't answer without additional information.
Ok, that is helpful. As mentioned, perhaps it is in "safe mode" or what Dodge trucks used to call "limp mode". Though those usually include a CEL or other warning light.
When driving it will it also not exceed 4000 RPM?
Discussion Starter · #11 ·
when driving it take the rpm normally
it is a 2016, june.
and I think it is the safe mode too but do you know how to get rid off ? because I asked to some that have the same car automatic and no one have that problem...
Discussion Starter · #12 ·
I believe that the AT has a rev limit of approx 3k when in neutral..... perhaps other AT owners can confirm this ? Also, are you 100% certain that you don't have the speed limiter set ????
A friend of mine has the same still in automatic and it can revs up to 7000rpm, no speed limiter set
Guys, this is a very well-documented issue, be sure to forum search.
In auto the engine will protect itself and won’t rev upwards of 4k when not in gear, just because. Usually after a few initial revs without limit, then limit is stuck on there forever I think. Temp doesn’t matter.
Reactions: Arthur
for s
That’s normal, there is a 4k rev limit in neutral.
Reactions: Arthur
a
and how can I get rid of ?
A tune can remove it. You would need to purchase a tune, like from EC, and ask that removing it be included (may cost additional fee for the feature).
thank you, and do you know where I can buy it exactly ?
EC tune:
I don't know whether or not you need to pay for removing the neutral rev limiter, but here's a link to the add ons. You should call or email them.
1 - 20 of 24 Posts
