If it exceeds 107C then we are truly in a world of troubleWell, I spend half the time in southern California, where the ambient temperature sometimes exceeds 107, and when in the direct sunlight a lot more, and add the heat from the engine, and what do you have? I know there are some other socal wrapped 124s, and I wonder what there experience is, although they probably haven't gone through a summer yet.
Look again, that's 107C not 107F. That would be 224 degrees Farenheit - not likely even in CaliforniaWell, I spend half the time in southern California, where the ambient temperature sometimes exceeds 107, and when in the direct sunlight a lot more, and add the heat from the engine, and what do you have? I know there are some other socal wrapped 124s, and I wonder what there experience is, although they probably haven't gone through a summer yet.
Thanks, we like the fit too. They are Black Enkei TS-10 Wheel Set 17x8, 40mm offset from Auto Ricambi, no aftermarket spacers needed.Can you say something about your wheel/tire size and if you use spacers?
They fit perfect.![]()
