Hi all,
I can't get my Keyless Start to pick up either key. I've replaced the batteries in both keys with verified good batteries (I have another 124 that I tested the battery in the key for keyless start worked). The keys unlock the car perfectly. I am able to get into ACC mode but the Start button flashes orange when I press the clutch to start because it is not picking the key up. The Green key symbol on the speedo does not light. Only the Red Anti theft symbol illuminates (Which i believe is normal).
It's worth noting the car had been sitting for months. About a week ago I revived it with a Jump from my other car. The keyless was playing up then but I just thought that was due to the dead battery as eventually it picked the key up. It had pretty bad moisture in the cabin which I think is probably the cause of this failure I did leave it running for a couple of hours last week with heaters fully on and windows slightly cracked to dehumidify but don't think I did a complete job and now in order to dry it out I need to start the car :/ However all the other electronics in the car are working A ok.
I have no errors in the infotainment nor have I seen an amber flash on the speedo indicating the car is aware of a keyless issue.
I have tried putting both keys up to the start button LOTS of times (I even removed the interior trim to expose the greet start button module. All looked okay and the key was right up against the PCB. No joy)
I've read tens of threads about various issues on here and miata forum, most of which seem to be rooted in bad batteries. I've read there is a procedure where you hold the Start/stop button which forces the car to start. However I can't seem to get it to do it (I held the button for well over 60s in both ACC and OFF positions).
I have checked the main fuse box in the bay and passenger side, I can't see any blown fuses but I have no idea where the fuse is that would relate to ignition as it doesn't seem to be pointed out in any of the manuals. I'm guessing its probably just part of one of the main engine management fuses.
This car is just two months out of warranty and is a track car only so I'd rather not have to pay multiple hundreds of £££ to get this sorted. I know the antenna module is buried in the dash so could get in there and try and diagnose but to be honest I'd rather just completely subvert it all. I haven't even seen anywhere I can get ahold of any replacement modules for keyless start (I found a Start button replacement from a wrecker but really don't think the button is the issue). I've seen there is a dealer tool called WiTech in the US but is expensive and hard to get ahold of but could diagnose/reregister the keys.
What are my options for starting the car? or Any way of just completely bypassing this keyless system, installing my own? Has anyone ever been able to do that force start procedure in the manual?
Anything I should get open to do diagnostics or check connectors or anyting?
Can a dead battery bork the Keyless system somehow?
Any ideas on how I can dry out the cabin without power?
I really really wish they had just put a f**king ignition barrel on the steering column.
Thanks in advance for any support
