intake problem and solution
2 reading
3.1K views 1 reply 2 participants last post by  sl_austin
#1 ·
For some time i felt a loose in power .Also saw that my max boost fall to half 0.86 bar max. I thought I have a leak on boost and I built a leak test kit.
In the mean time one day I decide to check the air filter and when I dismount the filter cover with the AF/turbo pipe connection this is what I found.
Because the oem pipe is made of 2 segments that are connected in the middle ,inside the pipe there is a inner ring to give opposite strength to the hose.
I found that this ring rotate 90 degree and was closing half of the pipe.
I choose to share this because it can happen to all of us running on stock .
In order to forget about this problem I decided to build my own intake pipe.
#2 ·
edit: sorry wrong thread
