Hello Guys,
I'm writing this thread because yesterday while I was driving something really weird happened and I want to rule out my theories. I'm going to be as detailed as posible.
While cruising yesterday I pressed the clutch to shift and the pedal stayed on the floor. So In the mean time I had to rev match to shift. After a couple of minutes I reached with my hand the pedal and brought it back. After that I said to myself if the pedal goes back down I'm screwed. So I pressed the pedal and was considerably stiffer. I had to push harder to get it down and now can't bottom end it like as usual it has like a it adding pressure so I can't reach the bottom. I can start the car and run it. Right now it's just the that the pedal is considerably stiffer.
Can anyone here give some guidance.
Thanks
Thanks
