Test set up:
2017 Spider Lusso
Automatic Transmission
EuroCompulsion Euro-Drive Lite-Dynamic Tune
EuroCompulsion V1 Air Intake
Home made muffler delete
Full tank of gas
Ambient Temp-75 F
Inlet Air Temperature 89-82 F
Traction Control Off
Car left in Drive letting it shift at 6250 rpm.
Top Down
Only me in the car(155 lbs)
Tire Air Pressure 29.1 PSI
Recording device-Ultra gauge OBDII instrument/use VSS for data collection
Flat asphalt road...as much as you can tell...
I made multiple runs. Without loading the torque converter produces the slowest 0-60 of 6.92 sec. This converter will not flash very high so that is why it is slow this way. You can load the converter up to around 2600-2700 rpm. This produced the fastest time of 6.40 seconds but also produced wheel spin out of the hole. I had multiple runs of 6.44 to 6.48 seconds. On a stickier surface I believe you may be able to load it a little more, possibly to almost 3000 rpm. With the top up, a cooler morning and a stickier surface a 6.0 or 5.9 could be possible. Manually shifting the automatic may also produce a faster time due the requirement of the transmission to make a shift from 2 to 3 right before 60 mph. My next runs will be made manually shifting the car. I will try to get out early in the morning to make some manual runs.
2017 Spider Lusso
Full tank of gas
Ambient Temp-75 F
Top Down
