I figured it might be helpful to have a list of oils and filters available for this car so people can choose between their options. This is will be updated as needed, so if you have something that should be added, let me know in a reply and I can update this thread. Please do not use this thread to debate the flaws or virtues of any of these products.
Note: Generally speaking, any BMW 229.5 (Full-SAPS) o 229.51 (Low-SAPS) spec synthetic 5W-40 oil will be suitable for use in this engine. Manufacturers have started recommend oils that meet both of those specifications for the 1.4L Multiair turbo. The below list still needs to be updated but has a few options to consider.
Engine Oils: The owner's manual recommends synthetic SAE 5W-40 engine oils meeting MS-12991 specifications. The following engine oils are available, in alphabetical order.
Full-SAPS oils:
- AMSOIL European Formula 5W-40 Classic ESP (25% off available with a Preferred Customer account) - Technical Data Sheet - Recommended for this engine by the oil manufacturer, but does not list MS-12991.
- Havoline ProDS 5w-40 - Technical Data Sheet - Meets the MS-12991 specification.
- Motul X-cess 5W-40 - Technical Data Sheet - Recommended for this engine by the oil manufacturer, but does not list MS-12991.
- Pennzoil Platinum Euro 5W-40 (Rebates may be available) - Technical Data Sheet - Dealer fill oil, meets MS-12991
- Ravenol 5W-40 VST - Technical Data Sheet - Lists MS-12991 but does not claim compliance or approval, listed under "Practice and tested in aggregates with filling."
- Shell Helix Ultra 5W-40 - Technical Data Sheet - This is probably identical to Pennzoil Platinum Euro 5W-40. Meets MS-12991.
- Total Quartz 9000 Energy 5W-40 - Technical Data Sheet - Meets the MS-12991 specification.
Low-SAPS oils that are recommended for this engine by the oil manufacturer. Note: these low-SAPS oils have reduced additive levels. See post 8.
- Castrol Edge 5W-40 - Technical Data Sheet - Recommended in by Castrol for this engine, but does not list MS-12991.
- Castrol Magnatec 5W-40 - Technical Data Sheet - Recommended in by Castrol for this engine, but does not list MS-12991.
- Valvoline 5W-40 MST SynPower - Technical Data Sheet - Lists the spec, but does not have OEM approval.
Oil Filters:
- FRAM CH9713
- Hastings LF669
- Mann HU 713/1 x
- Mopar 68102241AA
- WIX 57341
Full-SAPS oils:
Oil Filters:
- FRAM CH9713
- Hastings LF669
- Mann HU 713/1 x
- Mopar 68102241AA
- WIX 57341
